Humoro kampelis
Autorius: isgerkim
eddie_gt4 2008-01-11 12:41:12 (0)
jaunimas, sita istorija apkeliavo puse pasaulio auto-forumu, tad pries pateikdami savo teorijas, paguglintumete, ar ka tai :D
stai liudytojo "parodymai" :P
"Hello all,
I was at the event and know the guy who owns the car. (No it wasn't me)
I was in the paddock area next to him changing wheels at the same time as him. I watched him torque all of them. I even borrowed his torque wrench to tighten mine (I always forget something after I get on the road).
He went to a wheel/tire business and asked for spline drive lug nuts for his particular make/model/year car for the Enkeis, and that's what they gave him. He did not purchase the tires or wheels from them, just the lug nuts.
The lug nuts where sheared off the studs. Several members lifted a corner of the car to slide a jack underneath it. With a few more jacks, blocks of wood, etc, they were able to mount the stock wheels and stock lugs nuts (at least 3 per wheel) back on, torque them and drive the car off course. The design of the car, possilbly for aerodynamics, tucks all mechanicals on the underside a little higher than the body line, or lowest part of the brake rotors. Not even the exhaust was really scratched.
I'm not a mechanic, but the mechanics theories there was that the lug nuts where the incorrect size, but they were just small enough to grip the outer edge of the threads (as I mentioned, they torqued to 75-80 ft/lbs without complaint).
Hopefully, the only damage is to the body and brakes..."
isgerkim 2008-01-11 13:45:02 (0)
Mazda MX6 Vilnius Žinučių forume: 285
kazkaip cia nesupratau esmes ne taip nei su teksto verteju :D gal paaiskintum kame cia bendrai snekama ir kame prikolas? nekaltas :D
eric@info.lt
skype: isgerkim
mob: 867153999
amaratas 2008-01-15 01:57:16 (0)
celica 4wd carlos sainz vilnius Žinučių forume: 214
gal ir pasikartosiu, tixliai nepamenu buwo nebuwo... bet cia visko po biski...:P
uz saikinga alkoholio wartojima..Atidaryti naujame lange
kada vyrai pradeda vairuotiAtidaryti naujame lange
kalbancios katesAtidaryti naujame lange
Sheikhas Klubo narys 2008-01-15 06:30:28 (0)
isgerkim raše:
na as supratau, kad zhmogus (tas kuriam nulakste ratai) juos prisuko per mazomis verzlemis (tokiomis, kokios buna skarbonkiniams ratlankiams, o ne specialiai lietiems enkey), o ratlankiai nuo ju ir nusimove, verzles liko prisuktos :D To pasekoje pazeisti stabdziai ir ismetimo sistema.
zaibacas 2008-01-15 08:49:39 (0)
amaratas +5 jau ble zvengiau is tos kates paskutines :D :D :D :D
skype: zaibacas3
mob. nr. +37068971397
isgerkim 2008-01-18 07:00:01 (0)
Šūdų klasifikacija pagal pojūčius
Čia pateikiama šūdų klasifikacija remiantis šikėjo pojūčiais:
Šūdas-vaiduoklis – žmogus sunkiai ir įtemptai šika, bet šūdo klozete nėra
Švarus šūdas – žmogus sunkiai ir įtemptai šika, šūdas matomas klozete, bet nėra žymių ant tualetinio popieriaus
Šlapias šūdas – nors valotės šiknaskylę bent 50 kartų, vistiek jaučiate, kad dar visko nenusivalėte. Galiausiai, kad neišteptumėte trusikų, jums tenka įsidėti popieriaus į kelnes
Antrosios bangos šūdas – pašikate, išsivalote su tualetiniu popieriumi, apsimaunate kelnes, bet vėl pajaučiate norą
Užkietėjęs šūdas – jums tenka taip stengtis, kad vos negaunate širdies smūgio
Sunkus šūdas – pašikę netenkate 20 kg svorio.
Šūdas-plyta – jis toks didelis, kad prieš nuleidžiant vandenį jums tenka jį suskaldyti į mažus gabalėlius (ne ranka, žinoma, o tualetiniu šepečiu)
Dujinis šūdas – išeina su tokiu triukšmu, kad girdi visi 100 metrų atstumu
Alkoholinis šūdas – iššikamas ryte po girtai praleistos nakties. Jis limpa prie klozeto sienelių
Laukiamas šūdas – einate šikti, tačiau tik pasėdite ant klozeto ir keletą kartų nusibezdate
Plėšiantis šūdas – išlenda su tokiu skausmu, kad atrodo, kad perplėš jus pusiau
Besitaškantis šūdas – iššauna su tokiu pagreičiu ir taip pliumpteli, kad vanduo aptaško jums užpakalį
Skystas šūdas – teka srovele
Šūdas-apgavikas – jūs gi tik ruošėtės nusipersti...
Aukštuomenės šūdas – toks, kuris nesmirda
Nuodingas šūdas – nuo jo kvapo visame name išnyksta tarakonai.
Limpantis šūdas – prilimpa prie šiknaplaukių, ir jums reikia gerokai pakratyti subinę, kad jis pagaliau nusileistų išvietės skylėn
Meksikietiškas šūdas – tokio aštraus kvapo, kad jūsų nosis dega.
Nesibaigiantis šūdas – jis tęsiasi ir tęsiasi ir tęsiasi... Jūs meldžiatės, kad pagaliau pasibaigtų.
Nemirtingas šūdas – nuleidus vandenį vistiek plaukioja klozete.
Šūdas - pasalūnas – niekada nepasitaiko jums esant namie, o tik tuomet, kai esante kur nors išėjęs visai dienai. Jūs norėjote tik šiek tiek pirstelėti, tačiau visą dieną turite vaikščioti su pusiau iššiktu šūdu trusikuose.
Šampanizuotas šūdas – kai jūsų viduriai užkietėję, šūdų kamštis vistiek kada nors iššauna, kartu su burbuliuojančia ruda srove.
Šūdas - ledkalnis – unitaze pusė jo plaukioja po vandenio, o kita pusė virš vandens.
Sprogstantis šūdas – po jo seka toks galingas pirstelėjimas, kad jums tenka įsitikinti, ar neįskilo unitazas.
Šūdas egzorcistas – gelsvai - rusvas skystis šauna iš jūsų šiknaskylės, ją nudegindamas, ir ištykšta ant tualeto sienų (žr. skystas šūdas)
rekomenduojama isspausdinti ir tualete ant dureliu kababint :D
eric@info.lt
skype: isgerkim
mob: 867153999
jarik Klubo narysModeratorius 2008-01-18 08:33:40 (0)
:D :D :D
Romeo07 Klubo narys 2008-01-18 09:14:30 (0)
As jau atsispauzdinau. Pakabinsiu darbe tualete:D :D :D
Email: almantas.suk@gmail.com
Skype: almantas835
AST 2008-01-18 17:18:52 (0)
AT-180 (Sti 1.6) Londonas- Kupiskis Žinučių forume: 877
Va cia tai ismintis:D :D :D :D
greitai lėksi- lėtai neš, tad vazinekim protingai.
asttck@gmail.com
Skype: Audrius Stankunas AST
Romasius 2008-01-18 20:57:03 (0)
Vilnius Žinučių forume: 906
Cia geras.taip :D
Tel.nr.bite-865617005.
Skype:romasiui
