Hyundai konceptas. Turetu buti idomu! :)
Autorius: tomykas
| Gincius | 2008-03-20 08:27:15 (0) |
Grazus automobilis,plius dar galas varomas "Lenktynes-yra gyvenimas,visa kita tik laukimas" Kartingo lenktyniu serija www.kart-live.lt |
| tomykas | 2008-03-20 08:36:13 (0) |
| Žinučių forume: 1748 | Cia jeigu kam idomu (matau eddie idomu) tai siek tiek info daugiau VIDEO ![]() video2: http://www.youtube.com/watch?v=xATdPwTEk08 ![]() ![]() ![]() ![]() ![]() ![]() Hyundai Genesis Video from www.Hyundanews.com ALL-NEW HYUNDAI GENESIS COUPE: A NEW BENCHMARK FOR ATTAINABLE 300-HORSEPOWER SPORT COUPES New York, 03/19/2008 Genesis Coupe Specifications Hyundai unveiled Genesis Coupe, the new benchmark for attainable 300-horsepower sport coupes, during a press conference at the New York International Auto Show today. The 2010 Genesis Coupe is a purpose-built rear-wheel drive sport coupe featuring two performance-focused engines – a 212-horsepower (est.), 2.0-liter turbocharged four-cylinder engine and a range-topping all-aluminum, 306-horsepower (est.), DOHC 3.8-liter V6 engine. Genesis Coupe is scheduled to join the Hyundai lineup in the spring of 2009. GENESIS COUPE HIGHLIGHTS • Hyundai’s second rear-wheel drive performance car • 306 horsepower (est.)from enhanced 3.8-liter V6 from Genesis sedan • Std. 212 horsepower (est.) turbocharged, intercooled inline four cylinder • Genesis Coupe arrives in the spring of 2009 as a 2010 model Following the introduction earlier this year of the rear-wheel drive Genesis sport sedan, Genesis Coupe is Hyundai’s most dynamic performance car ever and the second consecutive all-new model introduction from Hyundai appealing directly to the car enthusiast. Genesis Coupe uses the same flexible rear-wheel drive architecture originally developed for the Genesis sport sedan. We think our entry-level Genesis Coupe 2.0t, with its unique combination of rear-wheel drive and four-cylinder turbo power, offers an intriguing alternative to existing front-wheel drive sport coupes,” said John Krafcik, vice president, product development and strategic planning, Hyundai Motor America. “The 3.8-liter version of Genesis Coupe takes driving to an even higher level, rivaling the capability of premium-performance coupes like the Infiniti G37.” Genesis Coupe’s arching roofline and tapering greenhouse highlight the exterior profile and emphasize the car’s broad shoulders and wide stance. The Genesis Coupe’s rocker panels are drawn close to the ground making the bodysides extra thick and the daylight opening thin, allowing the wheels to be slammed up into bulging fenders. To complete the aggressive sports car look, the depth between the fenders and the greenhouse has been maximized. Large openings in the front fascia allow for better engine breathing. The dual exhaust tips integrated into the rear fascia with surrounding blackout repeat the design theme of the front fascia graphic. Genesis Coupe rides on standard 18-inch alloy wheels or optional 19-inch wheels, both delivering a bold stance and aggressive handling. INTERIOR DESIGN In keeping with its mission to be the most exciting, attainable sport coupe on the road, the Genesis Coupe boasts a cockpit designed to enhance the driving experience. An information display screen features an outside temperature reading and audio system information. Analog gauges include a large speedometer and tachometer positioned so the driver can immediately access critical driving information. The instrument cluster features Hyundai’s signature blue gauge illumination. Bucket front seats with large side bolsters offer excellent lateral support for enthusiastic driving. High-quality seating surfaces range from full black fabric on the Genesis Coupe GS and GT, to optional full black or brown leather on the GT, to red cloth inserts with black leather bolsters on the SE. Among the other refinements are an Infinity audio system and two-stage front seat warmers. Genesis Coupe also offers the convenience of a Smart Key and push-button starter. REAR-WHEEL-DRIVE ARCHITECTURE ] Genesis Coupe’s body shell is rich in ultra-high-tensile steel. Genesis Coupe is lighter than the Infiniti G37, and its chassis is also 24 percent stiffer in bending rigidity than the BMW E46 M3. Rear-wheel drive provides a 55:45 front/rear weight distribution. POWERTRAINS Two engines infuse Genesis Coupe with performance. The 3.8-liter Lambda DOHC V6 engine delivers an estimated 306 horsepower (310 horsepower using premium fuel) and 263 lb.-ft. of torque on regular unleaded. This engine will launch the Genesis Coupe from 0 to 60 miles per hour in under six seconds. To maximize the power band, the 3.8-liter engine utilizes Continuously Variable Valve Timing (CVVT) on intake cam shafts and a new Variable Intake System (VIS) that helps cylinders breathe efficiently at both low and high RPM. The better breathing results in outstanding off-the-line acceleration and passing performance, and remarkable fuel efficiency. The V6 engine uses an alloy block and cylinder heads for lighter weight and thermal efficiency, and features timing chains with no scheduled maintenance. The turbocharged, intercooled 2.0-liter DOHC inline four-cylinder benefits from CVVT on both the intake and exhaust camshafts. The 2.0-liter turbo generates an estimated 212 horsepower (223 horsepower using premium fuel) and 217 lb.-ft. of torque. It also features a cast-aluminum cylinder block and cylinder head. Both engines feature a free flowing dual cat-back exhaust and an available limited slip differential to put the power to the ground. SPORT-TUNED SUSPENSION Genesis Coupe employs a MacPherson strut dual-link front suspension and a five-link rear suspension setup. The front suspension is mounted to the body via a solid subframe which is lighter and stronger than a multi-piece component would be. To help reduce body roll and tune the Genesis Coupe’s at-the-limit handling for maximum predictability, 23-mm diameter front and 18-mm diameter rear stabilizer bars are used. 2010 Genesis Coupe MacPherson strut dual-link front suspension 2010 Genesis Coupe Five-link Rear Suspension While all Genesis Coupe models offer a fun and sporty driving experience, the high-performance Genesis Coupe SE is a most willing partner for the true enthusiast. The SE’s track-tuned sport suspension features a stiffer front spring rate, stiffer rear spring rate and unique shock valving. Genesis Coupe SE delivers an increase in roll control over the GS. Superb structural rigidity sets the foundation for precisely-tuned handling performance in all Genesis Coupes. STEERING Hydraulic rack-and-pinion steering with a quick ratio gear delivers both linearity and agility. The steering is also engine-RPM sensing. TRANSMISSIONS Both engines are mated to a standard six-speed manual transmission. The Genesis Coupe 2.0t offers an optional five-speed automatic with SHIFTRONIC® while the 3.8-liter V6 offers a ZF six-speed automatic transmission with SHIFTRONIC to handle the additional torque. Drivers can access the SHIFTRONIC® feature by moving the gear selector into a separate gate. Pushing the selector forward or pulling it rearward will shift the transmission up or down sequentially, adding to driver control. A clear LCD readout on the instrument panel shows the gear that’s in use. HIGH PERFORMANCE BRAKING SYSTEMS Brembo four-piston calipers clamp down on 13.4-inch front brake rotors and 13-inch rear rotors on SE models. All other models get substantial 12.6-inch front ventilated rotors and 12.4-inch rotors in the rear with floating single piston calipers. INNOVATIVE TECHNOLOGIES The 2010 Genesis Coupe offers Xenon high-intensity discharge (HID) headlights. The advantages of HID headlamps include greater lighting power, daylight-type lighting and reduced power consumption. In addition, the cut lines of the new HID headlights are extremely precise, providing maximum nighttime visibility without distracting other drivers. Music lovers will welcome the 2010 Genesis Coupe’s standard auxiliary input jacks (3.5 mm mini-jack and USB input) to accommodate and charge audio devices such as iPods®. When an iPod or flash drive is connected through the USB port, located in the center storage compartment, not only does it play music through the vehicle’s audio system, but it also charges the iPod and allows the driver to access tracks with the steering wheel audio controls. This system also allows both driver and passengers to easily view song/artist/title information and control the music from the audio head unit rather than only the iPod itself. SEGMENT-LEADING SAFETY TECHNOLOGIES In keeping with Hyundai’s focus on offering segment-leading standard safety technologies across its lineup, the 2010 Genesis Coupe includes a wide range of both active and passive safety features. Standard safety technology includes driver and front passenger advanced frontal airbags, along with front seat-mounted side airbags, side air curtains and active front head restraints. Genesis Coupe has strong unibody construction, along with front and rear crumple zones, bodyside reinforcements, and five-mph energy-absorbing bumpers. The hood also includes buckling creases and safety stops. The front seatbelts have pretensioners and force limiters, and the rear seats feature LATCH (Lower Anchors and Tethers for Children), which make affixing child safety seats easier. All Genesis Coupe models feature standard four-channel ABS with Electronic Brake-force Distribution (EBD) to optimize brake performance under various dynamic loading conditions. The system also includes Brake Assist, which provides maximum ABS-level braking force when a panic stop is detected. Electronic Stability Control (ESC), one of the industry’s most effective life-saving technologies, is standard in all Genesis Coupes. Insurance Institute for Highway Safety (IIHS) studies suggest vehicles equipped with ESC experience 56 percent fewer fatalities in single-vehicle crashes. THREE DISTINCT TRIM LEVELS The Genesis Coupe is offered in three trim levels: the stylish and affordable GS, the premium-sport GT featuring the 3.8-liter V6, and the high-performance SE, available with either the 2.0-liter turbocharged four-cylinder engine or the 3.8-liter V6 engine. GENESIS COUPE GS (Preliminary packaging subject to change) Key Standard Equipment: • 2.0-liter turbocharged, intercooled four-cylinder engine • Electronic Stability Control • Traction Control System • ABS • Tire Pressure Monitoring System • Front, side, side air curtain air bags • Active front head restraints • Manual A/C • Keyless entry • Power windows, door locks, and mirrors • AM/FM/XM/CD Player/USB/iPod connectivity • Steering wheel audio controls • Cruise control • Vanity mirror illumination • Bluetooth GENESIS COUPE GT (Preliminary packaging subject to change) GS equipment Plus: • 3.8-liter DOHC V6 • Leather steering wheel / Shift knob • Metalgrain /chrome interior accents • Automatic temperature control • Fog lamps • Premium door sill plates • Trip computer • Chrome front fascia accents • Auto light control GENESIS COUPE SE (Preliminary packaging subject to change) Unique SE equipment: • 2.0-liter turbocharged four-cylinder or 3.8-liter DOHC V6 • HID headlights • Aluminum pedals • Manual A/C • 19-inch alloy wheels • High performance Bridgestone Potenza RE050A summer tires • Brembo braking system with monobloc four-piston calipers • SE track-tuned suspension / front strut brace • Limited-slip differential • Black leather bolsters / red cloth insert seats • Rear spoiler • Aero wiper blades GENESIS COUPE SPECIFICATIONS Configuration: Front engine, rear-wheel drive Wheelbase: 2820 mm / 111.0 inches Overall length: 4630 mm / 182.3 inches Overall width: 1865 mm / 73.4 inches Overall height: 1380 mm / 54.3 inches Wheels: 18-inch or 19-inch five-spoke Engine types: 3.8-liter V6 or 2.0-liter 4-cylinder turbo Est. horsepower V6: 306 @ 6,000 rpm (regular fuel) Est. horsepower V6: 310 @ 6,000 rpm (premium fuel) Est. torque V6: 263 lb. ft. @ 4,700 rpm (regular and premium fuel) Est. horsepower 2.0t: 212 @ 6,000 rpm (regular fuel) Est. horsepower 2.0t: 223 @ 6,000 rpm (premium fuel) Est. torque 2.0t: 217 lb. ft. @ 2,500 rpm (regular and premium fuel) Block & head materials: aluminum for both engines Valvetrain: DOHC for both engines Valve timing: continuously variable valve timing for both engines (Dual for 2.0t) Estimated 0-60 mph V6: under 6 seconds Transmission types: 6-speed manual, 5-speed automatic (4-cylinder) or 6-speed manual, 6-speed automatic (V6) Front brakes: 12.6-inch (standard) 13.4-inch (Brembo package) Rear brakes: 12.4-inch (standard) 13.0-inch (Brembo package) Front calipers: single piston floating (standard), monobloc four-piston (Brembo package) Rear calipers: single piston floating (standard) monobloc four-piston (Brembo package) Limited slip differential (Optional) Est. top speed: 149 mph (V6), 137 mph (2.0t) Base curb weight: 3549 lbs. (V6); 3439 lbs. (4-cylinder) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Hyundai Genesis Coupe To Appear in Fast and Furious 4 Quote: NEW YORK — It's no secret that the movie Fast and Furious 4 is already confirmed for production and that the new Nissan GT-R will have a starring role. But as the production powerhouse sets about gathering other vehicles, sources at Hyundai told Inside Line today at the 2008 New York Auto Show that Universal came to Hyundai asking for its new rear-wheel-drive Genesis Coupe to be part of the action. Although Fast and Furious 4 isn't scheduled for release until the summer of 2009, Hyundai has already committed to providing a red turbocharged 2.0-liter four-cylinder Genesis Coupe SE to the mix. Returning cast members include Paul Walker and Vin Diesel. The base coupe's 2.0-liter all-aluminum turbo four-cylinder is the fruit of the same Global Engineering Manufacturing Alliance that produced the 291-horse, 2.0-liter turbo in the Mitsubishi Lancer Evolution and 300-horse, 2.4-liter turbo that powers the Dodge Caliber SRT-4. Output from the north/south-oriented engine will be significantly less-212 horses at 6000 rpm and 217 pound-feet of torque at 2500 rpm-to give buyers a reason to pick the V-6. Hyundai did engineer some headroom for the tuning and drifting set; the blown and intercooled I-4 features a low 9.3:1 compression and can take boost up to 29 psi. Like the V-6, Hyundai is certifying the engine to run on regular or premium unleaded. With the latter, horsepower jumps to 223. Hyundai planning lightweight Genesis coupe, targa model to follow On the eve of the official unveiling of the Genesis coupe, we were able to score a few details from company execs about the future of Hyundai's first foray into turbocharged, rear-wheel-drive goodness. While Hyundai will only be showing off two versions of the Genesis coupe in New York, more variants are planned for the future, including a targa model sporting a retractable glass roof (ala Porsche 911 Targa), a convertible, and, more compelling, a lightweight version only offered with the 2.0-liter, turbocharged four-cylinder. Hyundai admits that only so much can be done to shed pounds from the coupe, which is already a rather portly beast to begin with, but by nixing some of the sound deadening material and possibly ditching the rear seats, Hyundai hopes that the sporting nature of the Genesis coupe will be fully realized. Naturally, this proposed lightweight model would have even more appeal to enthusiasts and could foretell a future motorsports campaign from an automaker that has thus far stayed off the performance junkie's radar. We'll have a full report after Hyundai's press conference tomorrow, so check back in around 3:50 pm for the full scoop on the Genesis coupe. EX '91 Celica GT-i |
| OSU | 2008-03-20 08:41:49 (0) |
| Vilnius Žinučių forume: 202 | Oho, is 2 litru su turba ispaudzia >200 AG, kaip kokia Celica GT4 www.fightclub.lt |
| eddie_gt4 | 2008-03-20 08:42:54 (0) |
tomykas raše: Cia jeigu kam idomu (matau eddie idomu) tai siek tiek info daugiau tomykai, buciau as moderas, gautum velniu... taigi savo zinutej imeciau nuoroda i ta video ir t.t. ir kam det visa sia info i CK puslapi, ir ji iskraipyt? gugliu siais laikais jau beveik visi naudotis moka p.s. pirmos dvi fotkes tai nemirtingos - Hiundaujui prifotozpinti naujos STI'skes ratai stock'in'fanas © by Sheikhas fleimmeisteris © by hedo |
| tomykas | 2008-03-20 08:46:16 (0) |
| Žinučių forume: 1748 | OSU raše: Oho, is 2 litru su turba ispaudzia >200 AG, kaip kokia Celica GT4 intercooled I-4 features a low 9.3:1 compression and can take boost up to 29 psi. on premium unleaded horsepower jumps to 223. eddie_gt4 raše: tomykas raše: Cia jeigu kam idomu (matau eddie idomu) tai siek tiek info daugiau tomykai, buciau as moderas, gautum velniu... taigi savo zinutej imeciau nuoroda i ta video ir t.t. ir kam det visa sia info i CK puslapi, ir ji iskraipyt? gugliu siais laikais jau beveik visi naudotis moka p.s. pirmos dvi fotkes tai nemirtingos - Hiundaujui prifotozpinti naujos STI'skes ratai jo sory, nepastebejau del video.. gugliu tikrai nevisi moka naudotis. a ten antri ratai tai nuo 350z man atrodo.. kaip patys hyundai sako sita masina skirta tuneriams. jie palieka dideles galimybes ja tobulinti ir pan. mano akimis ji tikrai turi potenciala. tiek del isvaizdos tiek del galios.. PS. engine start mygtukas EX '91 Celica GT-i |
| OSU | 2008-03-20 09:49:20 (0) |
| Vilnius Žinučių forume: 202 | Nu tai sakau kaip celica GT4. O sheikho dar ir daugiau gali www.fightclub.lt |
| tomykas | 2008-03-20 10:05:55 (0) |
| Žinučių forume: 1748 | OSU raše: Nu tai sakau kaip celica GT4. O sheikho dar ir daugiau gali jeigu tu apie 6gen tai taip. tikrai ne 5gen. 6gen dar galingesne stocke EX '91 Celica GT-i |
| hedo | 2008-03-20 10:37:24 (0) |
puse velnio, reiktu prieki pakeist ir is start/stop mygiuko islupt melynas neonkes .p.s. is tu palyginimu supratau, kad noriu bmw 335 . tai yra mano nuomone, kuri gali nesutapti su Jusu nuomone. As tikrai jos nepersu ir neprasau ja aklai vadovautis. Darykite ka norite ir kaip norite! Copyright by milZinas©2006 |
| ViR2 | 2008-03-20 11:08:26 (0) |
kaip hiundajui tai visai gerai tik, kad dizainas ish visu po bishky sukopintas '10 Alfa Romeo MiTo 155 '65 Porsche 911 Ex Celica GTi, ex Supra MKIII Turbo www.TUKA.lt |
| Toredo | 2008-03-20 11:20:52 (0) |
galas primena pirmo peugeoto 406 kupe Today Tomorrow TOYOTA |
