    celicos lengvinimas?
    Autorius: NightWalker
    PylX Klubo narysModeratorius 2006-08-18 15:02:28 (0)
    ir seip nevalges uz vairo sesk ir kilimelius isiimk nes zn...nieko nekainuoja
    ir apskritai jei kalbi apie masinos ale tiuninga/lengvinima ir pan ir tuo paciu apie atsipirkima tai siulau kreiptis i ten kur sienos minkstesnes...nors ir jos trbt neatsiperka :) ))
    apskrtitai malonumas retai atsiperka
    ViR2 2006-08-18 15:18:20 (0)
    Marciokas raše:
    800lt tai cia pigu? tada nenoriu..:)
    Kaip uzh tokias...? net labai pigu ;)
    '10 Alfa Romeo MiTo 155
    '65 Porsche 911
    www.TUKA.lt
    Drumbash 2006-08-24 11:54:53 (0)
    Šiauliai Žinučių forume: 47
    Crankshaft
    16
    Intake resonator box 0.7 No pipe work
    Air conditioning system 17.3 6.9 - Pump
    2.6 - Chiller
    3.1 - Radiator
    1.6 - Pipe work
    1.5 - Cooling fan
    0.8 - Mounting brackets
    0.6 - Liquid receiver
    0.2 - Sensors etc
    ??? - Refrigerant
    Catalytic converter 10.9 Aussie DP weighs 2.4
    Exhaust 6.4 - Centre section Scorpion exhaust weight:
    1 - Front
    4.5 - Centre
    5 - Rear
    Starter motor 3.9
    Passenger radiator fan 2.6
    Alternator bracket 2.0
    Drivers side engine mount 1.6
    Carbon canister and mounting bracket 1.5 1.3 - Canister
    0.2 - Mounting bracket
    Air intake box 1.1 - with stock filter
    0.79 - empty
    Radiator overflow tank 1.4 With pipes
    IC pump 1.3 With bracket
    185 CS without bracket 2.0
    Air intake box to turbo pipe work 1.0
    EGR system 1.0 Pipework, VSVs and bolts
    Intake manifold support struts 0.7
    Alternator cooling duct 0.5
    TVSV, TVIS VSV and mounting plate 0.5
    IC hard pipes above gearbox 0.4
    Battery clamp and plastic under tray 0.4
    Gearbox mount cover 0.4
    Pre air filter pipe work and fitting etc 0.4
    Cambelt top cover 0.3
    Rear wheel disk backing cover 0.3
    TVIS components 0.2 Butterfly valves etc
    Transmission
    Item Weight Note
    Gearbox 86.4
    Rear diff 26.1
    Propshaft 20
    Steering rack 9.4 With pipe work
    Rear drive shaft 7.4
    Front hub 5.8 Without shielding
    Laikas viska mesti laukan ;)
    ST185 GT-Four SOLD !
