KA patartumet daryti?
Autorius: Vitaminaszzz
| Vitaminaszzz | 2011-12-29 23:55:33 (-2) |
a tai ka del kompo darit juk mano netiktu beto kiek man ta galva kainuotu nes in plika neliptu |
2011-12-30 06:31:32 (0) |
šiaip 5sfe blokas yra vienas iš stipriausių, turbinistai specialiai ima 5s-fe bloką ir geda 3s-gte galvą, gaunasi 5S-GTE Taiginorint, viskas pritaikoma... |
| Povilas | 2011-12-30 09:39:26 (0) |
Kompas tau tiktu esamas , o galva paiekojas manau rastum uz koki 100lt. |
| Vitaminaszzz | 2011-12-30 11:52:39 (0) |
cia biski radau info There is a misconception as to whether or not the head and block will match due to the water jackets on the block in comparison to the head gasket and cylinder head. Let’s clear that up. All 3SGTE cylinder heads will bolt on to your 5SFE block and vice versa! Although it may not be a direct bolt-on without modification for the +1994 5SFE engine blocks, 1992-1993 blocks should be a direct bolt on with the proper head gasket. 5SFE engine blocks that do require machining only need the water jackets to be drilled out and matched up to whichever head gasket that you will be using. To avoid having to pay money on machining, your best off getting the +98 5SFE block. The problem is that you have to pay more for the block, but the water jackets match up PLUS you get the benefits of this cylinder walls and the reinforced water pump area. You MUST use the same year 3SGTE components (in a particular grouping), whether it be the wiring harness, timing components, fuel rail, exhaust/intake manifold, igniter, etc. The same model 3SGTE parts are grouped by years: ’91-92’ (Rev. 1 Gen 2), ’93-95 (Rev. 2 Gen 2), +’96 (Gen 3). Required/Minimum Parts Needed: 3SGTE Cylinder head 5SFE Crankshaft machined to fit 3SGTE Connecting Rods 5SFE Block 3SGTE Intake Manifold & Throttle Body 3SGTE Fuel rail w/ fuel injectors 3SGTE Timing Components: Timing Belt, Tensioner, Idler Pulley, Crankshaft Timing Gear, 1999-2003 5SFE Solara Oil Pump or 3SGTE (High-Volume) Oil Pump, ALL 3SGTE Timing cover components 5SFE Water Pump, Thermostat, Thermostat Housing (MR2's and Celica's should use the 91-93 MR2 5SFE water pump and thermostat housing AND 3S Thermostat.) 5SFE Coolant Hard lines aka Bypass Pipes (from a Camry. See "parts information" below for details.) 5SFE Oil Cooler 3SGTE Oil Pan (Refer to "Parts Information: Oil Pan" below) 3SGTE Oil Dipstick assembly 3SGTE Igniter/Coil 3SGTE Rotor, Cap, Spark Plug Wires, Distributor 3SGTE Crank Pulley (Rev. specific), serpentine/alternator belts. 3SGTE 2bar MAP Sensor MAF Sensor or AIT Sensor (GM) 3SGTE Exhaust Manifold Turbo (e.g. CT20b/CT26) that is either internally or externally wastegated 3SGTE Engine Wiring Harness (to splice up with the 5SFE wiring harness. (Refer to "Parts Information: Engine Wiring Harness" below) Cold Spark Plugs Upgraded Fuel Pump ATS Racing's 5SGTE Head Gasket or 3SGTE Head Gasket (Refer to "Parts Information: Head Gasket" below) Stroker spec Pistons (manufacturers don’t list as 5SGE/5SGTE, may be listed as "5SFE block with 3SGTE head" or "5SFE/3SGTE Head" 3SGTE Connecting Rods Fuel Pressure Regulator Blow Off Valve 3SGTE Standalone Engine Management System or ECU Custom Down Pipe Custom Cat-Back Exhaust Custom Intercooler and Piping Recommendations: Remove the balance shaft from the 5sfe crankshaft. These are prone to destroy themselves which can result in a damaged block. +98 5SFE Block. (See "parts information" below for details.) ARP Head Studs, Main Studs Oil Catch Can Dual Core-Radiator Custom Torque Rod Highly Recommended for +300hp: CRW Racing Inner CV Joint Cages (not necessary for RWD/AWD applications) ATS Racing Outer CV Joint Cages Anti-Torque Rod |
| Povilas | 2011-12-30 16:24:29 (0) |
Na cia tiek visko reikia jau rimciau darant, turbinini varijanta. |
| Gyconis | 2012-01-05 16:07:38 (1) |
Vitaminaszzz parašė: Ziekit uzdosiu off topic klausima uz kiek galeciau det pardavineti celica 2.2 visa noreciau ir skubiai pasiemiau zvakes tik koloneles ir akuma pyplaidzius paliksiu motorui ragas 500 lt beverte ji newaziuojanti Toyota Celica GT SS-II sold Toyota Celica ST sold Toyota Celica GT-four |
| Ciunia | 2012-01-05 16:08:32 (3) |
Vitaminaszzz parašė: Ziekit uzdosiu off topic klausima uz kiek galeciau det pardavineti celica 2.2 visa noreciau ir skubiai pasiemiau zvakes tik koloneles ir akuma pyplaidzius paliksiu motorui ragas Žmogau Tu mokyklą baigęs ? Vitaminaszzz parašė: .. uz kiek galeciau det pardavineti celica 2.2 visa.. Į metalą priduok |
| TRIUMF | 2012-01-05 18:50:03 (0) |
tai eik kur grazesne kalba sneka... |
