Ar eina pakeist 7gen gt i gts variklius?
Autorius: sieras
| Gytis | 2008-03-06 14:09:15 (0) |
11 cia lambo or what |
| hedo | 2008-03-06 14:20:37 (0) |
kadangi diskusija taip netiketai nukrypo i lankas , leisiu sau paklaust: ar "DYI ported header" kazkokius pokycius sukele? tai yra mano nuomone, kuri gali nesutapti su Jusu nuomone. As tikrai jos nepersu ir neprasau ja aklai vadovautis. Darykite ka norite ir kaip norite! Copyright by milZinas©2006 |
2008-03-06 14:22:20 (0) |
Gytis raše: 11 cia lambo or what Isvirtimo reguliavimas galui. Kaip zinia, standartiskai to nera. Rear camber links (plates). |
2008-03-07 11:03:54 (0) |
By request I have started this as an FAQ, parts list, depository for peoples experiences etc. etc. etc. Anyways basic parts list: Complete 2ZZ with manifolds, injectors, sensors and engine harness 2ZZ flywheel 2ZZ ECU or 2ZZ Power FC 2ZZ knock sensor appropriate to your ECU choice C60 tranny (if desired - not necessary) pass. side engine mount 2ZZ CAI or stock air box and tubes Throttle cable from cruise control to engine Combination meter or aftermarket tach GTS Midpipe (or at least the front flange from one) 2ZZ alternator if you can think of any info you would like in this thread please post the questions here. If you have done this or have info to add please feel free to do so Additional information * When you order your motor remember that 2003+ GTS engine came DBW * Matrix / Vibe / Voltz / Corolla XRS intake manifolds are different and will require fabrication of a custom intake tube * Air INjection started in 04 - if you get a full air injection motor and header you will have to cap the feed pipe or cut off and weld the air injection tube closed * GTS Knock sensor changed in 2002 to a 2 wire sensor - this sensor is not compatible with the earlier ECUs * The GTS got a lower rev limiter in 2002 and DBW in 2003+ so make sure to get a 2000 or 2001 ECU * The 1ZZ clutch will bolt up to the 2ZZ flywheel, but the 1ZZ flywheel can NOT be bolted to the 2ZZ crank. Links and Resources 2ZZ Manifold identification Guide: http://www.newcelica.org/forums/showthread.php?t=205642 Diskusija sia tema http://newcelica.org/forums/showthread.php?t=226223 |
| Edgaras | 2008-03-07 12:38:57 (0) |
zycha o kuro sanaudos nepadidejo po "butterfly mod"? man isrodo, kad kuo daugiau oro, tuo daugiau kuro..? It gets a little bit worse before it gets a little less better. |
2008-03-07 13:12:54 (0) |
oras lengviau pakliuna. |
Romeo07
2008-03-07 14:23:49 (0) |
Edgaras raše: zycha o kuro sanaudos nepadidejo po "butterfly mod"? man isrodo, kad kuo daugiau oro, tuo daugiau kuro..? oro nedaugiau pakliuna, o lengviau. Cia skirtingi dalykai. Email: almantas.suk@gmail.com Skype: almantas835 |
| Edgaras | 2008-03-08 09:07:19 (0) |
todel kuro daugiau nevartoja, ye? jei taip tai susigundysiu isbandyt su savo tC, jei ten yra toks drugelis.. nes su situo pusbakiu sanaudos ~16l/100 jis kartais isproteja It gets a little bit worse before it gets a little less better. |
| Adrijus | 2008-03-08 14:53:34 (0) |
zycha: tie 'hotchik' camber links biskuti kainas prilaiko, alternatyvius camberius turi SPC, tiek kad ne bling bling ir kaina perpus mazesne p.s. o prieki isvirtimas geras pas tave? pamenu kad man reikejo netgi priekinius varztus keisti norint tureti normalu isvirtima. got boost? |
2008-03-08 17:46:19 (0) |
Adrijus raše: zycha: tie 'hotchik' camber links biskuti kainas prilaiko, alternatyvius camberius turi SPC, tiek kad ne bling bling ir kaina perpus mazesne p.s. o prieki isvirtimas geras pas tave? pamenu kad man reikejo netgi priekinius varztus keisti norint tureti normalu isvirtima. priekis puse velnio, bet galas tai labai isvirtes reikia viska lyginti.Camber links gamina Hotchkis, SPC, Eibach. Pasirodo, isvirtima gale galima susireguliuoti paciam, be jokiu daiktu pirkimo Kazkaip prazioplinau tai |
