b145t3r MR2 Turbo
Autorius: b145t3r
| b145t3r | 2011-05-20 09:46:45 (3) |
Prisistatysiu ir as, ypac kai dabar turiu kuo pasigirti. Taigi dabar vairuoju MR2 GT (1991m LHD) ir MR2 Turbo (gime budamas N/A 1992m RHD, perdarytas i rev3 3S-GTE) Dabar apie kiekviena atskirai. Apie MR2 GT : paprastas 3S-GE stock variklis (o ka ten is jo isbursi..) Fast Road clutch (up to 320bhp) HSD coilovers Delphi stabilizatoriaus traukes Poliuretanines stabilizatoriaus ivores O dabar apie tik ka isigyta zaisliuka (cia tai jau rimciau )Ratus suka pilnai per nauja surinktas rev3 3S-GTE, kuris pagal Dyno suka: Maximum Power – Wheels 271.6 bhp @ 6,063 rpm Maximum Power – Engine 312.1 bhp @ 6,063 rpm Maximum Torque 293,7lbft (396,8 nm) @ 4694 rpm Kaip sakiau variklis naujai surinktas: Rev3 Block 3S-GTE 86.00mm JE forged piston kit Carillo 3S-GTE rod kit 5.433 CT26 stage 3 turbo fully ported, blueprinted & balanced to racing standarts, 48mm compressor wheel with large diameter steel shaft, 360 degree thrust bearing, 12psi actuator Twin plate 700 series rally clutch 700 flywheel Release bearing carrier 700 release bearing, low load type 700 bolt kit rev3 oil pump TRD low temp thermostat Cosmo fuel regulator ARP main and head stud kit TRD iridium plugs SAMCO RED hoses HKS steel head gasket ST205 dump pipe Revision 6 Radtec Chargecooler New Genuine Toyota 3S-GTE crankshaft and bearings HKS blow-off valve Magnecor zvakiu laidai Link G3 ECU MR2 Turbo Mongoose Exhaust Magnetic drain plug Na ir kalnas visokiu mielaciu tokiu kaip naujas skriejikas, davikliai t.t ir panasiai Vaziuokle: R17 su Goodyear Eagle F1 Koni top adjustable shocks Fensport Racing F1 progressive spring kit Stainless braided competition brake lines DOT 5.1 brake fluid New handbrake cables Reconditioned calipers New Master and Slave cylinder Grooved and Drilled brake discs Carbotech Panther Plus brake pads Exterior: Modifikuotas priekinis bamperis APR Performance GTC – 300 Carbon Rear Wing Interior: Persiutas salonas i oda, Boost gauge Oil pressure gauge Gali but kad kazka praleidau, nes yra kalnas tai patvirtinanciu popieriu, bet kadangi bandziau kategorijom surasyt, tai visko gali but. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() www.powerlab.cz |
| Ciunia | 2011-05-20 09:49:52 (0) |
Foto ? |
| Fanaz | 2011-05-20 10:02:06 (0) |
Varikliukas tokis ir buvo ar pats perrinkai? |
| b145t3r | 2011-05-20 10:09:45 (0) |
Fanaz parašė: Varikliukas tokis ir buvo ar pats perrinkai? toki pajamiau.. viskas daryta servise..www.powerlab.cz |
| GreddyMR2 | 2011-05-20 10:13:06 (0) |
Dar kartą pasveikinsiu Kad tik laikytų tas varikliukas... |
2011-05-20 10:50:02 (0) |
truksta tik CLEAN look, bet modai teisingi >PAST: Celica:3x 5gen GTI, 5gen GT4, 6gen ST, 7gen GT. Honda Civic: 6gen LSI, 7gen Type-R, Lexus IS...i know that cars >NOW: SAAB 9-3 2.0T MapTune Stage 1 |
| b145t3r | 2011-05-20 10:57:35 (0) |
PylX parašė: truksta tik CLEAN look, bet modai teisingi zinau.. bet jis biski pastovejes, seimininkas ji apleides buvo truputeli, todel taip ir atrodo.istaisysiu sita klaida www.powerlab.cz |
| b145t3r | 2011-05-20 11:05:09 (0) |
dabar klausimas, kol visiskai salta, pradejus vaziuot, nenori boostint. sushyla - normaliai pucia. kas gali but? apsauga kazkokia, kad turbos nepjaut? cia man buves seimininkas skundes ir demonstravo.. www.powerlab.cz |
2011-05-20 11:14:22 (0) |
ne nu bet chebra... )) salta boostinti tai jau no way... nors siep k atu laikai salta? palaiko pastoviai maza slegi ar apskritai neleidzia boostinti t.y iki 0 ir viskas? placiau papasakok pasakysiu kas gali but >PAST: Celica:3x 5gen GTI, 5gen GT4, 6gen ST, 7gen GT. Honda Civic: 6gen LSI, 7gen Type-R, Lexus IS...i know that cars >NOW: SAAB 9-3 2.0T MapTune Stage 1 |
| b145t3r | 2011-05-20 11:22:25 (0) |
as ja turiu tik antra diena tai dar neissiaiskinau. karoce. uzkure, sako salta neboostina, tipo ziurek, paspaudzia ciut ne dugna, o jinai springsta, trukcioja. sako susils, pakils temp rodykle ir prades pust normaliai. nu taip ir buvo. as puikiai zinau kad saltos smaugti negalima, bet man atrodo kad jam vienodai sviete. faktas, kad jam nesigaudavo puuuust is karto www.powerlab.cz |
