Toyotu sukimo momento lentele
Autorius: zhigan_limon
zhigan_limon
2008-05-10 19:54:58 (0) |
Na manau forumui tokia tema nepakenks TORQUE SPECIFICATIONS TOYOTA APPLICATION FT-LBS (N-m) AXLE SPINDLE NUT CAMRY (1994-92) 217 (294) CELICA (1992) & SUPRA 203 (276) CELICA (1994-93) 166 (226) CRESSIDA (REAR 1993-92) 203 (276) CELICA ALL-TRAC (REAR 1993-92) 166 (226) PREVIA & TERCEL 166 (226) MR2 (1994-91) NON-TURBO 152 (206) TURBO 217 (294) ALL OTHERS 137 (185) AXLE SHAFT-TO-FLANGE BOLT 27 (37) AXLE SHAFT-TO-FLANGE NUT (FRONT) CAMRY ALL-TRAC, V6 & CELICA ALL-TRAC 48 (65) CAMRY (ALL OTHERS), CELICA, COROLLA, FX, & MR2 27 (37) PICKUP, VAN, & 4RUNNER 61 (83) PREVIA 51 (69) AXLE SHAFT-TO-FLANGE NUT (REAR) MR2 TURBO 48 (65) ALL OTHERS 51 (69) CRESSIDA & SUPRA 51 (69) BRAKE CALIPER BOLT 65-70 (88-95) CENTER BEARING LOCK BOLT 24 (33) CV JOINT BOLT 25 (34) INTERMEDIATE SHAFT MOUNT 40 (54) LOCKING HUB BODY-TO-AXLE BOLT 23 (31) LOCKING HUB CENTER BOLT 13 (18) LOWER BALL JOINT-TO-STEERING KNUCKLE CAMRY V6 83 (113) CAMRY (ALL OTHERS), CELICA & PREVIA 94 (128) COROLLA (1989-84) 47 (64) COROLLA (1994-90) 105 (142) LOWER CONTROL ARM-TO-BALL JOINT NUTS/BOLTS PASEO & TERCEL (1994-91) 59 (80) LOWER SUSPENSION ARM-TO-AXLE HUB CARRIER BOLT 83 (113) STRUT-TO-AXLE HUB CARRIER NUT 167 (227) STRUT-TO-KNUCKLE BOLT CAMRY 152-166 (207-226) COROLLA DIESEL ENGINE 152 (206) GAS ENGINE 105 (142) TERCEL 105 (142) STRUT ROD-TO-LOWER SUSPENSION ARM BOLT 83 (113) SUSPENSION ROD NUT 36 (49) SWAY BAR NUT 35 (47) TIE ROD END NUT MR2 (1994-91) 76 (103) ALL OTHERS 32-36 (43-49) WHEEL LUG NUT 70-80 (95-109) Top of the range JDM Toyota MR2 Turbo 96 JDM Toyota Soarer 92 Mercedes S320 CDI 2004 |
| eddie_gt4 | 2008-05-10 19:57:39 (0) |
nu bet gal tik ne sukimo momento, o uz-sukimo? stock'in'fanas © by Sheikhas fleimmeisteris © by hedo |
zhigan_limon
2008-05-10 20:00:01 (0) |
waewa Top of the range JDM Toyota MR2 Turbo 96 JDM Toyota Soarer 92 Mercedes S320 CDI 2004 |
