Kompo nuresetinimas
Autorius: jarik
2005-09-13 18:08:46 (0) |
How to read the codes? 1. turn ignition on, but don't start the engine 2. short the check engine connector (or between T and ground) 3. check engine light will now blink indicating the code. Count the number of successive blinks and that's the code. Be aware that there may be more than one trouble code stored, in which case the next displayed code is different. There is a 3 second pause between the codes. Codes will be repeated until you remove the short in check engine connector. 4. Clear the codes by removing the "stop" fuse, or disconnect the battery for at least 30 seconds. ce tik ant greicio turiu piesinukus ir tixlej viska ce irgi extrem,alai atjungiet siulo :D kita diena ikelsiu lekiu alaus /) >PAST: Celica:3x 5gen GTI, 5gen GT4, 6gen ST, 7gen GT. Honda Civic: 6gen LSI, 7gen Type-R, Lexus IS...i know that cars >NOW: SAAB 9-3 2.0T MapTune Stage 1 |
| ViR2 | 2005-09-13 18:43:55 (0) |
butu gerai, kad su pic'ais nes nelabai supratau :) '10 Alfa Romeo MiTo 155 '65 Porsche 911 Ex Celica GTi, ex Supra MKIII Turbo www.TUKA.lt |
| aidelizz | 2005-09-14 21:22:10 (0) |
PylXas raše: isitikinimas:) na bet jei tas isitikinimas padeda mano masinai netrukciot tai man tai patinka:) |
| ViR2 | 2005-09-15 19:50:38 (0) |
na tai laukiam konkrechiau kaip viska atlikt ;) '10 Alfa Romeo MiTo 155 '65 Porsche 911 Ex Celica GTi, ex Supra MKIII Turbo www.TUKA.lt |
| Isjunges_Tel | 2005-11-13 16:50:27 (0) |
Blyn padariau tik nzn ar teisingai. ECU saugiklio nerandu nzn kuri lupt.Efi ir hazard radau. ar cia tik GTI cielkutems ar ir sti padetu? krc istraukiau "dome" saugikliuka. bet masina po to veike tai bent tiek gerai :D Tikras kaifas - kai gali sau leisti vaziuoti letai... +37069874080 |
| nemo | 2005-11-14 12:41:50 (0) |
Kaip jums pavyksta istraukt tuos saugiklius ?? Arba as ne tuos radau ar ka, bet pas mane jie tokie dideli kaip rele ir as ju negaliu istraukt :( |
| Infinitis_ | 2005-11-14 13:18:16 (0) |
| Celica Vilnius Žinučių forume: 38 | Kurioj vietoj tie saugikliai randasi konkrecei?:) |
| Infinitis_ | 2005-11-14 13:18:44 (0) |
2005-11-14 14:01:10 (0) |
saugikliu blokas po kapotu. Ten kruvele reliu (lempu, kuro pompos ir kt) bei saugikliu. Norint nurezetinti reikia istraukti elementaru saugikli EFI ir palaikyti min 10s. Tada kompas nusirezetina ir pereina i selflearning mode, t.y. analizuoja koki kura pili, kokios eksploatavimo tamperaturos ir etc, pagal ka susireguliuoja. Keiciant kura, eksploatavimo salygas ir kt reiketu pastoviai nusirezetinti, tada lieka maziau siuksliu ir windowsas geriau sukasi :P |
| aklasis | 2005-11-14 20:29:59 (0) |
o mintis... anksciau pyliau 98 dabar perejau prie 95 - reiktu resetinti? Sold MR2 (first one in celica club) Sold H Civic B16 Ford Mondeo (Family budget saver) |
