    Kompo nuresetinimas
    Autorius: jarik
    jarik Klubo narysModeratorius 2005-08-28 12:17:04 (0)
    Zekit ka radau 6gc.net puslapyje apie kompo nuresetinima! :)
    Ka paie tai galvojat? ar suveiks sis bajeris ant 5 celikos ir ar istikruju pades?!
    If you've noticed lately your car has been running awkward or idling at very low rpms or even idling roughly, then your ECU needs to be reset. It is also a good idea to reset your ECU if you've added any performance mods like headers, intake, exhaust; doing this will let you take full advantage of your mods and reset your Air/Fuel mixture ratio so that you can get more horsepower and better gas mileage.
    Here's how to reset your ECU. First, start your car and let it warm up. When it's reached it normal operating temperature, turn the car off. Then, pop the hood and remove the Relay Fuses box cover and remove the following fuses: The Hazard fuse, the EFI fuse, and the ECU fuse. Take them out and leave them sit out for 1 minute. Then when the minute is up, put the fuses back in and start up your car. At this time the ECU is being reset so you can take advantage of your mods and get better gas mileage. When you start it up, let it run for exactly 10 minutes, then turn your car off. then start it again and you wil notice your car idle better and from that point on you will now have better gas mileage and your mods will be put to use.
    ViR2 2005-08-28 21:32:14 (0)
    kiek zhinau daugumoj mashinu pakanka papraschiausiai atjungti akuma ;)
    '10 Alfa Romeo MiTo 155
    '65 Porsche 911
    www.TUKA.lt
    jarik Klubo narysModeratorius 2005-08-29 07:03:04 (0)
    na.... o kai apart EFI is elektronikos dar turi gerai 'suprogramuota' maga, idomia signalizacija ir dar nezinia kokiu biesu, o ir laikrodi nustatinet is naujo tingi, tai manau galima ir saugiklius traukinet! ;)
    man idomiau ne pats procesas, o ka tai koknreciai duoda, ar tikrai padeda? Juk tie duomenys ir taip turetu visalaik atsinaujinti? Idomu per kiek laiko pilnau atsinaujina patys? o gal jis saugo visa savo istorija, ir todel is tikruju pravartu nuresetint ta kompa karts nuo karto?
    ViR2 2005-08-30 21:24:32 (0)
    na neteko man su celicos ecu susidurt, bet smartui tai akuma atjungdavau ir poto ratus galedavau prasukinet ant esfalto linksmai :D
    '65 Porsche 911
    www.TUKA.lt
    aklasis 2005-08-31 17:57:44 (0)
    kiek zinau maniskei tai kazka reikejo trumpinti - akumo atjungimas nieko neduoda. Dabar tik nepamenu ka konkreciai.
    Sold H Civic B16
    aidelizz 2005-09-13 16:34:34 (0)
    ZZT-231 (GT-S 1.8) Vilnius Žinučių forume: 384
    xaoc zinai ka as tau pasakysiu... pabandziau as atlikt sita procedura (5th tik kad yra du ecu saugikliai) na ir zinok gal man vaidenasi ar ka na bet man nebetrukcioja masina... is pirmos i antra imetus prie betkokiu apsuku normaliai viskas... gal tik sutapimas... bet man patiko :D
    jarik Klubo narysModeratorius 2005-09-13 16:39:49 (0)
    nu geras!! :D reiks ir man pabandyt! :)
    PylX Klubo narysModeratorius 2005-09-13 18:02:58 (0)
    isitikinimas:)
    PylX Klubo narysModeratorius 2005-09-13 18:04:34 (0)
    turiu ka reik uztrumpint ir nieko atjunginet nereik...paieskot ? :)
    jarik Klubo narysModeratorius 2005-09-13 18:05:33 (0)
    paieskok! :)
