    Kompiuterio klaidu taisymas
    Autorius: kvakiz
    kvakiz 2008-10-06 20:42:02 (0)
    Tai va dega pas mane airbag'u lempecka, nieks neissove viskas tvarkoj, priekis buvo kaltas tikrai, bet dacikai nepazeisti... tai ka? nusprendziau patikrinti klaidas, gavau tokius signalus I I III I (mirksejimas) tai kaip supratau 11klaida ir 31? ar ne? jei taip kaip jas istrinti ar jas butinai mechaniskai reikia pasalinti? nors atrodo kad viskas tvarkoj net neliesta tos vietos?
    Edvatronas Klubo narys 2008-10-07 04:23:35 (0)
    Pamegink klema akumo nuimti ir palaukti bent 10 sec.
    Edit:
    Siaip didesne pauze tarp klaidu turetu buti, nei, kad tu pavaizdavai... Jei 11 ir 31 tai:
    Code 11
    Short to ground in circuit between center air bag sensor and
    either air bag; faulty air bag; short to ground in circuit between
    front air bag sensor and center air bag sensor; faulty front air bag
    sensor; +S and -S circuits between front air bag sensor and center air
    bag sensor are shorted together; faulty spiral cable; faulty center
    air bag sensor.
    Code 31
    Faulty center air bag sensor.
    CLEARING CODES
    1) At DLC, connect a jumper wire to terminal Tc. See Figs. 11
    and 12. Connect another jumper wire to terminal AB. Turn ignition
    switch to ACC or ON position. Wait about 6 seconds.
    2) Starting with terminal Tc, apply body ground alternately
    to terminal Tc and terminal AB twice each, in cycles of 1/2 to 1 1/2
    seconds (sequence is: Tc, AB, Tc, AB) . Finally, keep applying body
    ground to terminal Tc until air bag warning light flashes quickly,
    indicating codes are cleared.
    NOTE: When alternately connecting jumper probes to terminals,
    simultaneously release one probe from one terminal while
    connecting other probe to other terminal. If time interval
    between probings exceeds 0.2 second, codes will not clear.
    Bet kodel taip sudetingai trinami klaidu kodai, tai man nedaeina... pavargęs
    SaltinisAtidaryti naujame lange
    Dogg 2008-10-07 06:28:49 (0)
    Ne nu tu cia ir pavariai :D
    Tu pirmiau nusiimk vairo airbaga, ir isitikink 100% ar airbag sveikas, nes kad dacikai ant lanzu sveikia tai cia visiskai ne rodiklis.
    Pas Toyota - jei dega airbagai, tai greiciausiai kad jie bus sove, arba nepajunkta kazkuris is Airbagu arba Dirzu. Buna dar ir dirzai uzsaunami, taip kad reikia gerai viska pirmiau pereiti ir perziureti ir isitikint ar viskas sveika, o tik paskui ieskot problemos Kompe Airbag.
    kvakiz 2008-10-07 07:06:09 (0)
    jei tikrai airbagai geri? kaip patikrinti dirzus ?
    Edvatronas Klubo narys 2008-10-07 07:59:23 (0)
    Manualus reikia skaityti.. ;)
    Bent jame tai nieko apie dirzus neraso...
    Ko gero dirzai neissaunantys...
    Karceris 2009-12-07 12:01:10 (0)
    situacija tokia,kad kompas ismete klaida 5.1. tikrinau sklendes davikli,lyg ir veikia,nes atsjungus variklis gesta spaudziant pedala.
    esme yra tokia,kad kol variklis saltas,visiskai nenori dirbti ir nelaikant ekseleratoriaus gesta. susyldzius iki normos, variklis dirba tvarkingai, bet vaziuojant visiskai nera traukos.
    gal kam yra teke susidurt su siuo kodu ir galetu patart kur ieskot saknu??
    GAS,GRASS OR ASS
    No One Rides For Free
    Karceris 2009-12-07 12:08:03 (0)
    specialiai meciau i klaidu taisyma,kad nekurti naujos temos,o cia pasirodo 6 kartos skyltis.. gal lbj nesupyksit,nes klausimas tikrai slegiantis i kuri atsakymo neturiu..
    GAS,GRASS OR ASS
    PylX Klubo narysModeratorius 2009-12-07 12:31:05 (0)
    is simptomu tai man panasu i maf`o grybavima. bet jei kompa srodo sklendes davikli patikrink ji neatjunginedamas o manuale pagal instruklcijas pamatuok varzas. kad atjungus isvis gesta dar nieko neparodo.
    Miinde 2009-12-07 13:54:30 (0)
    mr2 Vilnius Žinučių forume: 64
    bent jau audi dirzai tai varza turi buti arba jei sove stato varza ir nedega lempute, bet vat kiek nepamenu bet berods keli omai gal 9, bet ar pas emera kerta dirzus ?
    www.TavoAutoservisas.lt
    Karceris 2009-12-07 16:48:43 (0)
    bandysiu tikrint varzas. dekui uz minti ;)
    GAS,GRASS OR ASS
