    7gen Compiled Performance Mod Info and FAQ's
    zycha Klubo narysModeratorius 2007-11-16 16:30:13 (0)
    Common Bolt-On Engine Performance Modifications
    Cold air and short ram intakes
    - Blue Bomber (BB) Mod for intakes
    http://www.newcelica.org/forums/showthread.php?t=112681
    http://www.newcelica.org/forums/showthread.php?t=205453
    Exhaust systems
    - Common GT-S axle-back exhaust comparison by Turbo magazine
    http://www.turbomagazine.com/tech/0..._exhausts_test/
    - Other GT-S exhausts
    http://www.newcelica.org/forums/showthread.php?t=245404
    - GT axle-back comparisons
    http://www.newcelica.org/forums/showthread.php?t=245403
    - Sound clip database
    http://www.newcelica.org/forums/showthread.php?t=245405
    - NOTE: TRD Kazuma was the only cat-back exhaust ever produced. All other are axle-back (Greddy is often advertized as a cat-back).
    Exhaust headers and catalytic converters
    http://www.newcelica.org/forums/showthread.php?t=204266
    - "Race" headers
    http://www.newcelica.org/forums/showthread.php?t=237200
    http://www.newcelica.org/forums/showthread.php?t=230849
    http://www.newcelica.org/forums/showthread.php?t=229905
    http://www.newcelica.org/forums/showthread.php?t=230773
    - Cat deletion, O2 simulation and plug defoulers
    http://www.newcelica.org/forums/showthread.php?t=211552
    http://www.newcelica.org/forums/sho...&threadid=15130
    - Header ID and special considerations for 2003-05 model cars
    http://www.newcelica.org/forums/showthread.php?t=205642
    http://www.newcelica.org/forums/showthread.php?t=205889
    - Ceramic insulation coating
    http://www.newcelica.org/forums/showthread.php?t=196963
    - Exhaust manifold studs
    http://www.newcelica.org/forums/showthread.php?t=213279
    http://www.newcelica.org/forums/showthread.php?t=192388
    - Header install guide
    http://www.newcelica.org/forums/showthread.php?t=205898
    Underdrive pulleys & undampened pulleys
    http://www.newcelica.org/forums/showthread.php?t=110791
    http://www.newcelica.org/forums/showthread.php?t=111107
    http://www.newcelica.org/forums/showthread.php?t=111206
    http://www.newcelica.org/forums/showthread.php?t=21926
    http://www.newcelica.org/forums/showthread.php?t=119577
    Scam/eBay Mods that don't work
    - The Tornado
    http://www.newcelica.org/forums/showthread.php?t=75366
    - Fuel line magnets
    http://www.newcelica.org/forums/showthread.php?t=10916
    - Air temperature sensor resistor
    Other External Engine Modifications
    Lubrication system
    - Oil coolers
    http://www.newcelica.org/forums/showthread.php?t=133494
    http://www.newcelica.org/forums/sho...ad.php?t=194155
    - Oil pans
    http://www.newcelica.org/forums/showthread.php?t=177967
    Cooling system
    - Radiators
    http://www.newcelica.org/forums/showthread.php?t=202486
    - Low temperature thermostats
    http://www.newcelica.org/forums/showthread.php?t=210420
    http://www.newcelica.org/forums/showthread.php?t=184035
    Fuel system
    - Fuel pumps
    http://www.newcelica.org/forums/showthread.php?t=189412
    http://monkeywrenchracing.com/mwr_fuel_system.html
    - Stock vs. Walbro 255 lph
    http://www.newcelica.org/forums/showthread.php?t=190656
    - Fuel injectors
    Ignition system
    - Spark plugs
    http://www.newcelica.org/forums/sho...d.php?p=3176302
    - Ignition coils
    http://www.newcelica.org/forums/showthread.php?t=151267
    http://www.newcelica.org/forums/showthread.php?t=149615
    Belt tensioner/drive belt noise and part revision
    http://www.radphys.com/TSB_Belt_Tensioner.pdf
    http://www.newcelica.org/forums/showthread.php?t=158699
    Removal of air conditioning compressor
    http://newcelica.org/forums/showthread.php?t=190815
    Internal Engine Modifications
    Camshafts
    http://www.newcelica.org/forums/showthread.php?t=209845
    http://www.newcelica.org/forums/showthread.php?t=206868
    Valves, springs and retainers
    http://www.newcelica.org/forums/showthread.php?t=188039
    http://www.newcelica.org/forums/showthread.php?t=212987
    http://www.newcelica.org/forums/showthread.php?t=206435
    Cylinder head porting & polishing
    http://www.newcelica.org/forums/sho...d.php?p=3670976
    http://sportcompactcarweb.com/tech/..._cylinder_head/
    Big bore throttle body
    Pistons and compression ratios
    - Forged vs. cast pictons
    Connecting rods
    Cylinder liners and sleeves
    Crankshafts
    Oil pumps
    ARP head and main studs
    Performance and low-compression head gaskets
    High performance rod and main bearings
    Performance surface treatments
    - Low friction, oil dispersant, flow coatings
    - Cryogenic treatment
    Professional engine builders
    Drivetrain Modifications
    Clutches
    http://www.newcelica.org/forums/showthread.php?t=208709
    Flywheels
    http://www.newcelica.org/forums/showthread.php?t=70710
    - Flywheel bolt information
    Limited-slip differentials (LSD)
    - Clutch-type vs. helical
    Short shifters
    http://www.newcelica.org/forums/showthread.php?t=210641
    Upgraded/strengthened transmissions
    - Aftermarket gearsets
    - Common transmission damage and part revisions
    http://www.newcelica.org/forums/showthread.php?t=214602
    http://www.newcelica.org/forums/showthread.php?t=192866
    - 3S-GTE (E153) transmission conversion
    Automatic transmission upgrades
    http://www.newcelica.org/forums/showthread.php?t=101611
    Performance/custom axles
    http://www.newcelica.org/forums/showthread.php?t=214072
    Engine mounts and urethane bushings
    Shifter bushings and braided clutch lines
    - Shifter base bushings
    - Shift cable bushings
    - Brainded stainless clutch lines
    Engine control, electronics, gauges
    ECU Tuning Forum
    http://www.newcelica.org/forums/forumdisplay.php?f=208
    A'PEXi Power FC
    http://www.newcelica.org/forums/showthread.php?t=191180
    http://www.newcelica.org/forums/showthread.php?t=187685
    Greddy E-Manage/E-Manage Ultimate
    Hydra EMS
    http://www.newcelica.org/forums/showthread.php?t=212257
    Power Enterprises CAMCON
    http://www.newcelica.org/forums/showthread.php?t=213242
    Split Second
    AEM EMS
    A'PEXi S-AFC/S-AFC II/V-AFC
    http://www.newcelica.org/forums/showthread.php?t=113708
    Dastek UNICHIP
    http://www.newcelica.org/forums/showthread.php?t=54151
    Jet Chip
    http://www.newcelica.org/forums/showthread.php?t=96516
    Venom 400
    http://www.newcelica.org/forums/showthread.php?t=20630
    OEM Toyota ECU
    - Versions of ECU and part numbers
    - Rev limiter conversion for 2002 model year GT-S
    - Check Engine Light (CEL) codes and "resetting" the ECU
    - ECU pinout for GT-S
    - Learning function of ECU
    Changing "lift" engagement point on 2ZZ-GE engines
    Drive by wire (DBW) to cable throttle conversion
    http://www.newcelica.org/forums/showthread.php?t=205309
    Mechanical vs. Electrical gauges
    Oil pressure and temperature gauges
    Water temperature gauges
    Wideband oxyegn (O2) sensors
    http://www.newcelica.org/forums/showthread.php?t=188457
    - Why air/fuel gauges are different than widebands and don't work
    Exhaust gas temperature (EGT) gauges
    Forced Induction: Turbochargers, Superchargers and Nitrous
    Forced Induction & Nitrous Forum
    http://www.newcelica.org/forums/forumdisplay.php?f=46
    Turbo system FAQ
    http://www.newcelica.org/forums/showthread.php?t=199226
    Turbocharger kits
    - C2 Power (C2) http://www.c2power.com/
    http://www.newcelica.org/forums/showthread.php?t=211486
    - Hass Pro Turbo http://www.hassturbo.com/
    - XS Engineering http://www.xs-engineering.com/xssto...3&idproduct=634
    - Stafford Fabrication (SF)
    - ATR
    - David Draper (DD)
    DIY turbo systems
    Turbocharger manufacturers
    - Garrett http://www.turbobygarrett.com/
    - Turbonetics http://www.turboneticsinc.com/
    - HKS http://www.hksusa.com/
    - Greddy http://www.greddy.com/
    - IHI http://www.ihi-turbo.com/
    Turbocharger distributors
    - ATP http://www.atpturbo.com/
    - Precision Turbo http://www.precisionturbo.net/
    Wastegates and blow off valves (BOV)
    - Differences between internal and external wastegates
    Intercoolers
    - Air-to-air
    - Air-to-water
    - Differences
    Boost controllers
    http://sportcompactcarweb.com/tech/..._boost_control/
    How much turbo boost is safe to run?
    Cold air intakes on turbos
    Supercharger kits
    - Greddy
    http://www.newcelica.org/forums/sho...d.php?p=3513108
    http://www.newcelica.org/forums/showthread.php?t=229926
    - Blitz
    DIY supercharger systems
    http://www.newcelica.org/forums/showthread.php?t=167507
    How do I raise the boost on a supercharger?
    How much supercharger boost is safe to run?
    Can I intercool my supercharger?
    Is the Electric Supercharger legit?
    Turbocharger vs. supercharger
    Costs of forced induction systems
    Spark plugs for forced induction
    Clutches for forced induction
    Boost gauges
    Nitrous FAQ's and Install
    http://www.newcelica.org/forums/showthread.php?t=42600
    Nitrous kit manufacturers
    - Nitrous Oxide Systems (NOS)
    - Nitrous Express (NX)
    - Zex
    Nitrous system types
    - Wet
    - Dry
    - Wet vs. dry
    How much nitrous (shot) is safe to run?
    Other Performance Topics
    Suggestions for first time modders
    http://www.newcelica.org/forums/showthread.php?t=128245
    Weight reduction
    - Guide to weight reduction
    http://www.newcelica.org/forums/showthread.php?t=206358
    - Lightweight wheels and wheel diameter
    - What does weight reduction do?
    Engine swaps
    - 2ZZ-GE (GT-S) into Celica GT chassis
    http://www.newcelica.org/forums/showthread.php?t=226223
    - 3S-GTE swap (2nd Gen MR2 and 5th Gen Celica All-Trac)
    http://www.newcelica.org/forums/showthread.php?t=187790
    - Other engines
    Drag racing
    - 1/4 Mile Database
    http://www.newcelica.org/other/tracktimes/index.php
    - Setup and technique
    Technical Topics
    Repair & Maintenance Forum
    http://www.newcelica.org/forums/forumdisplay.php?f=52
    Celica Repair Manual - Toyota Big Green Book (BGB)
    http://www.newcelica.org/other/tech...als/volume1.pdf
    http://www.newcelica.org/other/tech...als/volume2.pdf
    - Toyota Tech Info Website
    Technical Service Bulletins (TSB) and maintenance schedules
    http://www.newcelica.org/forums/forumdisplay.php?f=59
    http://www.newcelica.org/forums/forumdisplay.php?f=60
    General car specifications and maintenance schedules
    http://www.newcelica.org/other/technical/specs/00.jpg
    http://www.newcelica.org/other/technical/specs/01.jpg
    http://www.newcelica.org/other/technical/specs/02.jpg
    ASE papers on 2ZZ-GE engine
    http://www.radphys.com/2zz_ge_article.pdf
    VVTi and VVL systems
    http://users.ameritech.net/trdcelic...Explanation.pdf
    Basic fuel injection controls information
    http://www.newcelica.org/forums/showthread.php?t=84901
    Common acronyms and abbreviations
    http://www.newcelica.org/forums/showthread.php?t=214876
    Gasoline and octane number
    http://www.newcelica.org/forums/showthread.php?t=197220
    http://www.newcelica.org/forums/showthread.php?t=202049
    Oils and gear lubes
    Dynomometer (dyno) types
    - Dynojet Model 248C
    - Dynapack
    - Mustang
    - Dyno Dynamics
    - Manufacturer engine dynos
    How a dyno works/what it reads
    http://sportcompactcarweb.com/tech/...c_sport_tuning/
    Comparison of different dynos
    Reviews of dynos and dyno shops
    Bad/fake dyno information
    http://www.newcelica.org/forums/showthread.php?t=206533
    http://www.newcelica.org/forums/showthread.php?t=196242
