Kokie buna 7gen zibintai?
2007-05-20 18:49:05 (0) |
There seems to be much confusion between the three so I wanted to clear up the air with some short descriptions and pic comparisons. Toyota OEM JDM tinted headlamps: -Smoked trim piece -Blue tinted low beam reflector -Blue tinted high beam reflector -Louver style slants on turn signal -Aimed towards the left side of the road TRD JDM Sports M headlamps: -Only available on the TRD Sports M Model as an option, not standard equipment -Less than 2,200 were produced -True HID projectors -4300k HID bulbs -3 hole projector design -Dark metallic gray casing -Aimed towards the left side of the road USDM aftermarket black headlamps: -Black trim piece -Silver low beam reflector -Chrome tinted high beam reflector -Aimed towards the right side of the road Toyota '04-'05 USDM OEM Action Package/Tsunami color matched headlamps: -Trim piece painted in the same color as the vehicle -Silver low beam reflector -Chrome tinted high beam reflector -Aimed towards the right side of the road Toyota '03+ USDM OEM HID headlamps: -True HID DOT compliant projectors -Built in motors to adjust the projectors up and down while sitting inside the car -4300k HID bulbs -Larger bulge at the top of the headlamp compared to '00-'05 OEM clear (due to the HID projector) -Metallic gray trim piece -Silver low beam reflector with holes -Chrome tinted high beam reflector -Aimed towards the right side of the road Toyota '00-'05 USDM OEM clear: -Clear trim piece -Silver low beam reflector -Chrome tinted high beam reflector -Aimed towards the right side of the road Visa informacia su paveiksliukais rasite cia |
2007-05-20 19:50:20 (0) |
OT: Gal jau pribrendo padaryt FAQ tema su nuorodomis i tokias temas kaip si? Panasiai kaip 5gen forume. Jus padarykit, o as priklijuosiu prie virsaus |
| Gytis | 2007-05-20 19:54:36 (0) |
aha, cia vien USDM ir JDM o kaip su EDM? |
